FloPoCo installation manual
Operators tend to come and go as we struggle to support them, and we apologize for that. Hopefully the new Autotest features will bring more stability. Meanwhile, it is possible that the operator you want works better in an older version: read the release notes.
Installation in Ubuntu and other Debian derivative
Versions (most recent on top)
Bleeding edge git master version
Recommended is the install script for the full version with all optional dependencies.
If something goes wrong, try the install script for a simpler version (fewer dependencies).
Version 4.1.2, the last one with the old pipelining framework
See the install script . It was written for ubuntu 16.04 (xenial), and is probably broken on more recent versions. In this case you can install it in a virtual machine using Vagrant as follows:
vagrant init ubuntu/xenial64 && vagrant up
vagrant ssh
# the following happens in the virtual machine
wget http://flopoco.gforge.inria.fr/install_scripts/install-plain-4.1.2-on-xenial64.sh
sh install-plain-4.1.2-on-xenial64.sh
Version 2.5.0, the last version before the transition to Sollya4 broke everything that bit heaps had not yet broken
See the the install script, that it tested to work in Ubuntu 12.04, aka "precise". You probably want to run it in Docker.
Version 2.3.2, the last version before the Great Leader embarked the project in the bit heap hazardous adventure
Older versions may include operators that have later been deprecated. Look up the source code repository
More installation scripts
For Debian/Ubuntu, simply look at this directory of installation scripts . Each script works for one environment, and Vagrant or Docker are your friends to set up this environment in a virtual machine.
Dependencies
For non-Debian systems, the installation scripts will give you an idea of the dependencies to install, in particular: Sollya (mandatory, used in a lot of operators), WCPG (optional, used in the FixIIR operator), and ScaLP (optional, will improve the quality of many operators).
ScaLP provides a uniform interface to several ILP solver. The instructions provided build ScaLP with the LPSolve back-end, which is the only backend for which installation can be fully automated. Better results may be obtained using other backends: SCIP, Gurobi (both freely available for academic purpose) or CPlex. You are therefore encouraged to download one of these, install it, then recompile ScaLP (adding the relevant arguments to its cmake command, see ScaLP documentation), then FloPoCo.
Installation by Docker
Installation in Windows
Here is a simple way to get FloPoCo running in a virtual machine under Windows. You will need to install :
Installing Ubuntu in a Vagrant virtual box
Create a folder where you want to contain all the Vagrant files.
Open a command prompt and go into this folder. If you are using windows, you can quickly open a command prompt by holding down shift and right-clicking the project folder, then choose “open command window here”.
Now type the following commands :
vagrant init ubuntu/focal64
vagrant up
The first time, it may take some time depending on your internet connection.
Connecting to the virtual machine by SSH
You have two solutions at this point :
Installing Flopoco on your virtual machine
Go to the Linux installation instructions : Copy one of the one-line installation scripts and paste it into the prompt of your virtual machine. Wait. Sometime, you will be asked to press "y".
Some common problems
If you encountered others problems, give us feedback and if possible solutions so that we can add them to the preceeding list.
