FloPoCo user manual
Installation instructions
List of operators with their command-line syntax
Command-line interface
FloPoCo is a command-line tool. The general syntax is
flopoco <options> <operator specification list>
FloPoCo will generate a single VHDL file (named by default flopoco.vhdl) containing synthesisable descriptions of all the operators listed in <operator specification list>, plus possibly sub-operators instanciated by them. To use these operators in your design, just add this generated file to your project.
FloPoCo will also issue a report with useful information about the generated operators, such as the pipeline depth. In addition, three levels of verbosity are available.
Built-in help
To obtain a concise list of the available operators and options, simply type
./flopoco
Examples
./flopoco IntConstMult wIn=16 c=12345
produces a file flopoco.vhdl containing a single operator for the integer multiplication of an input 16-bit number by the constant 12345. The VHDL entity is named after the operator specification, here IntConstMult_16_12345.
./flopoco IntConstMult wIn=16 c=12345 IntConstMult wIn=16 c=54321
produces a file flopoco.vhdl containing two VHDL entities and their architectures, for the two given constant multipliers.
Options
Several transversal options are available and will typically change the operators occuring after them in the list.
Helper programs
The FloPoCo distributions also includes useful programs for converting the binary string of a floating-point number to human-readable form (bin2fp) and back (fp2bin). The longacc2fp utility converts the fixed-point output of the LongAcc operator (see below) to human-readable form.
Floating-point format
The floating-point format used in FloPoCo is identical to the one used in FPLibrary. It is inspired from the IEEE-754 standard.
An FP number is a bit vector consisting of 4 fields. From left to right:
A 2-bit exception field
00 for zero, 01 for normal numbers, 10 for infinities, and 11 for NaN
A sign bit
0 for positive, 1 for negative
An exponent field on wE bits
It is biased as in IEEE-754. The smallest possible FP numbers have exponent field 00...00, the FP number 1.0 has the exponent field 011...11 and the largest possible FP numbers have exponent 11...11
A fraction field on wF bits
The actual significand has an implicit leading 1, so the fraction field ff...ff represents the significand 1.ff...ff
The format is therefore parameterized by to positive integers wE and wF which define the sizes of the exponent and fraction fields respectively.
The utilities fp2bin and bin2fp will allow you to get familiar with the format and set up test benches.
Difference between FloPoCo format and IEEE-754 format
There are two main differences between the format (wE=8, wF=23) and the IEEE-754 single precision format (the same holds for double).
Note that anyway, FloPoCo provides conversion operators from and to IEEE-754 formats (single and double precision).
LNS format
Numbers in the Logarithm Number System used in FloPoCo have an encoding similar to the floating-point format. It is also the same as the one used in FPLibrary.
Its fields are:
Same encoding as floating-point: 00 for zero, 01 for the general case, 10 for infinities, and 11 for NaN
A sign bit
The integral part of the exponent on wE bits
The fractional part of the exponent on wF bits
The fixed-point exponent is encoded in two's-complement.
Reasonable values are 4 to 8 for wE, and 8 to 20 for wF. Other values are still allowed, including negative wE. Use at your own risk.
Pipelining
An operator may be combinatorial, or pipelined. A combinatorial operator has pipeline depth 0. An operator of pipeline depth 1 is obtained by inserting one and only one register on any path from an input to an output. Hopefully, this divides the critical path delay by almost 2. An operator of pipeline depth 2 is obtained by inserting two register levels, etc.
It should be noted that, according to this definition, pipelined operators usually do not directly buffer neither their inputs nor their outputs. For instance, connecting the input of a 400MHz operator to the output of another 400MHz operator may well lead to a circuit working at 200MHz only. It is the responsibility of the user or calling program to insert one more level of registers between two FloPoCo operators. This convention may be felt as a burden to the user, but it is the most sensible choice. It makes it possible to assemble sub-component without inserting registers in many situations, thus reducing the latency of complex components. Besides, different application contexts may have different policies (registers on output, or registers on input).
Two command-line options control the pipelining of the FloPoCo operators that follow them.
pipeline=[yes|no] (default yes)
Requires the operators to be pipelined. If no, the operator will be combinatorial. If yes, registers may be inserted if needed to reach the target frequency.
frequency=[frequency in MHz]
Sets the target frequency. If the pipeline option is set, then FloPoCo will try to pipeline the operator to the given frequency. It will report a warning if it fails -- or if frequency-directed pipelining is not yet implemented for this operator.
The philosophy of FloPoCo's approach to pipelining is the following:
Note that not all operators support pipelining (utimately they all will). They are mentionned in the command-line help.
